Activity › Forums › Boris FX Particle Illusion › Particle Illusion 3 for OSX-Combustion User
  • Particle Illusion 3 for OSX-Combustion User
    Posted by Keith Hill on November 13, 2005 at 4:15 pm
    Hello,
    I am about to purchase v3.0 for use with Final Cut 5, Combustion 3.0.4, Motion 2 and Cinema 4D. I’m wondering how I will handle tracking when it comes to work in Combustion. I use the tracker in C3 alot and my understanding is that PI-3 doesn’t have a trakcer. So, how will I handle that going forward so I can tap into the power of the standalone PI-3?
    Keith Hill
    https://www.LightedPath.biz
    Dallas, TX
    Final Cut Pro 5.0.2, Motion 2.0.1, Combustion (MAC-v3.0.4), Cinema 4D r9.5, DVD StudioPro 4 (v 3.0.2); MAC G5 (v10.4.3-Tiger) 2Ghz, 1.5 RAM
    Elvis Deane replied 20 years, 10 months ago 2 Members · 1 Reply
  • Elvis Deane
    November 14, 2005 at 2:45 am
    Here’s an old post from Alan:
    In combustion 3 there is a button (“export”?) that exports the tracker data into an *.ascii file. You should be able to load that file directly into pI3 using the Import Position data function. Just select “text file” and select your .ascii file.
    I can’t remember if you need the latest 3.0.1a of pI3 to do that or not.
    You can give this a try with the demo version of pI3 and make sure that your tracking data comes through. Just right-click on an emitter in the hierarchy window, choose Import, and then grab that ascii file out of Combustion.
    Elvis Deane!
    The particleIllusion FAQ
    particleIllusion Resources and tutorial CD
    Astounding Adventures
