Activity Forums VEGAS Pro Particle generator / effects?
  • Particle generator / effects?
    Posted by Adam Spencer on February 22, 2011 at 10:10 am
    I’m trying to do some basic particle effects for a video. What I want to do is replace the ‘particles’ with an image.
    I’m having trouble finding a basic program or plugin to do this. I’ve tried a flash animator program (KoolMoves) and it does have a particle plugin, but the options are very limited.
    I tried Boris RED but that was just way too complicated. All I need is some basic pre-set effects that I can customize, and then output in an appropriate format that would retain transparency (that’s if I can’t find an actual Vegas plugin).
    I tried ParticleIllusion, but the standalone program doesn’t work with Windows 7 and it seems the only alternative is a plugin for AE.
    Any suggestions?
    Adam Spencer replied 15 years, 7 months ago 3 Members · 3 Replies
  • Theo Van laar
    February 22, 2011 at 11:12 am
    “I tried ParticleIllusion, but the standalone program doesn’t work with Windows 7 and it seems the only alternative is a plugin for AE.”
    Particle Illusion works perfect with windows 7 (I have windows 7-64 bits) on my computer and for what you describe that you want to do, it is your best option
    Theo
  • John Rofrano
    February 22, 2011 at 1:13 pm
    [Theo van Laar] “Particle Illusion works perfect with windows 7 (I have windows 7-64 bits) on my computer and for what you describe that you want to do, it is your best option”
    Same here. I’m using particleIllusion 3 with Windows 7 64-bit and it’s working fine. Download the trial and see for yourself. The standalone version has more features than the AE plug-in so that’s the better one to get.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Adam Spencer
    February 22, 2011 at 2:09 pm
    thanks guys, I’ve managed to get it working now.
