Activity Forums Apple Motion Particle emitter shows through object, help!
  • Particle emitter shows through object, help!
    Posted by Collin Alexander on December 26, 2007 at 5:45 pm
    This is driving me crazy.
    I’ve got a video in the foreground, and another video pushed way back. In between the two is a particle emitter. I want to rotate everything all around and show this from various angles. It all works and looks great. Except . . .
    I can see the particle emitter through the foreground video. Why? It’s behind it. Makes no sense.
    The opacity of the video is set to 100%. I’ve tried moving the particle emitter above the video group on the timeline, and also below it. I’ve tried moving the emitter into the same group as the videos.
    Either the emitter shows through the foreground video, or the the emitter goes behind both videos. I want it in between!
    Checking off “preserve opacity” on the emitter makes them disappear behind the black background, as if the background was an object with opacity.
    Help!
    Thanks.
    Collin Alexander replied 18 years, 8 months ago 2 Members · 3 Replies
  • David Bogie
    December 27, 2007 at 3:21 pm
    You seem to be implying you have a 3D composition.
    bogiesan
  • Collin Alexander
    December 29, 2007 at 11:22 pm
    Why yes, it’s a 3D composition in Motion.
    The blend modes are all set to “normal”. I’ve tried starting over, and I get the same thing.
    No matter what video, no matter what particle emitter, it always shows through the video.
    Can anyone else please confirm or deny they are having the same result?
    1. Place a video into a Motion comp.
    2. Hit new camera, make 3D
    3. Use the move tool in the HUD and move the video back into the background.
    4. Place a particle emitter into the comp.
    5. Position the emitter in front of the video.
    6. Place a second video in the comp.
    7. Rotate the camera and look at the situation from all angles. Verify that there is a particle emitter between two videos.
    Does the emitter show through or not?
    If it’s just a weird bug in Motion, I’ll stop worrying about it.
  • Collin Alexander
    January 2, 2008 at 9:37 pm
    Anybody? Please? Help?
