Activity › Forums › Apple Motion › Particle emitter in 3d space
  • Particle emitter in 3d space
    Posted by Jonathan Hess on October 2, 2014 at 1:34 pm
    Does anyone know, how I can use a 3D particle ring in 3d space? The picture shows it best.
    I have a particle ring with circles which is rotated -90° (x-axis). In the middle there is a white sqaure (or a logo). When I add a camera and turn to 3d it looks good (left image). But as soon as I check the 3D checkbox in the emitter, so all the particles face the camera, it breacks the 3d compositing (right image).
    Is there a possibility to fix that?
    Thanks for any kind of help.
    -Jonathan
    Simon Ubsdell replied 11 years, 12 months ago 2 Members · 3 Replies
  • Simon Ubsdell
    October 2, 2014 at 7:16 pm
    You need to make sure your group is set to 3D.
    Simon Ubsdell
    tokyo-uk.com
  • Jonathan Hess
    October 2, 2014 at 7:29 pm
    Hi Simon
    Thanks for your answer. The group is set to 3D. I switched it when I added the camera.
    But I figured out, that I can change the particle rendering from lokal 3D to global 3D. And now it works.
    I was working on a bigger project and there must be something corrupt in it because these settings doesn’t work there. But in a fresh project everything’s alright. So I have to rebuild this bigger project and hope that it will work.
    Btw: Simon you have really awesome motion tutorials, it’s really inspiring.
  • Simon Ubsdell
    October 2, 2014 at 7:41 pm
    Glad you got it sorted out. I have found that Motion projects that I’ve been working on for a really long time can start behaving strangely (especially recently in 5.1.2) – I think a lot of crud gets left behind in the XML after a while which doesn’t get fully cleared out.
    Very pleased to hear you like the tutorials. Thanks 🙂
    Simon Ubsdell
    tokyo-uk.com
