Activity › Forums › Apple Motion › Particle emitter creating light bursts
  • Duane Giliam
    December 12, 2010 at 12:48 pm
    HI Tim
    Thats a cool clip.
    Would a re timing behavior work – if there is such a thing.
    I imagine you would need to re time a glow effect to happen as they hit the floor.
    But I’m not sure how to target that “point in time if each particle is separate.
    It looks like you got closer to the over all effect than I managed.
    Duane
    Duane
    http://www.leapyearfilm.co.za
  • Anders Larsen
    December 13, 2010 at 2:41 pm
    Hi Tim
    As I see it, the biggest challenge in recreating this in Motion is that Motion does not let you make particles of a light.
    In the template you link to, the bouncing balls actually light up the floor, revealing the grungy texture.
    In order to achieve this I think you would have to make a handful of lights that bounce off a floor, and then duplicate or clone them until you have the desired effect.
    It will be time-consuming, but it’s not that difficult to do.
    First create a floor and the lit-up ball (a feathered circle with a light in the middle will do the trick) then apply a gravity behavior and then an edge collision behavior.
    This will make the ball fall to the bottom of the scene and bounce in place.
    Add a throw behavior to make the light bounce off to the side.
    When you have the timing just right, keyframe the intensity and falloff parameters of the light to give the light burst you need.
    Duplicate the ball a handful of times to make different versions of it, and then clone these versions as needed and drag the clones down the timeline at random intevals. you will need to make quite a few clones, so this step will take a while to do.
    Finally animate your camera, and upload your movie here, so we can all see your masterpiece.
    Wow! That ended up being a long post. Hope it all make sense.
    /Anders
  • Jimmylee Remillard
    December 15, 2010 at 3:07 am
    Hey, I have been thinkin a lot about remaking the video copilot tutorials for apple motion. I recreated the scene you are talking about for fun and could write up a tutorial on it if you would like. Here it is let me know what you think.
    https://animsspace.blogspot.com/2010/12/graphic-i-made-in-apples-motion.html
  • Duane Giliam
    December 15, 2010 at 5:38 am
    yes please Jim
    Duane
    December 19, 2010 at 12:47 am
    Hey, I made that tutorial, let me know what you think =D
    https://forums.creativecow.net/readpost/170/867656
  • Duane Giliam
    January 17, 2011 at 5:00 am
    Hi There
    Finally rotated back to the land of the living.
    Awsome Tutorial – Thanks for that.
    It would be nice if there was a way to get the particles flare slightly as they hit the floor. But still a very cool look.
    I was wondering where you got all those extra filters from – it appeared as though you have more than I do.
    Thanks again
    Duane
    Duane
    January 17, 2011 at 7:28 pm
    There are ways to make it “flare” when it hits the floor but thats more manual work for each section.
    To be honest i use maybe 1 or 2 of those filters, i have actually deleted most of them. Apples Motion doesn’t really have the plug-in community that After Effects has.
  • Tim Chivers
    January 18, 2011 at 5:39 pm
    sorry for my late reply
    trying to get back into a flow at work after Christmas!
    thanks for all the tips..i’ll give these a go
