Activity › Forums › Maxon Cinema 4D › Particle Dune
  • Particle Dune
    Posted by Virendra Chandekar on August 30, 2023 at 11:54 am
    Hello Folks,
    I am kinda’ stuck at this. The idea is to create a Sand dune forming. Sand just flows in from all directions to form this sand dune. How do I achieve this desired effect using C4D? Please help.
    All answers appreciated.
    Thank You in advance
    Virendra Chandekar replied 3 years ago 2 Members · 2 Replies
  • George Charoupas
    August 30, 2023 at 1:11 pm
    Hello,
    A rough procedure to create something like this is:
    1) You need to have first the sand model (like a very small cube or whatever you like). Avoid something with a lot of polygons.
    2) Create 4 emiters from 4 sides to emit the sand model in the center. This is to simulate the sand coming from all directions. Make the emiters big enough to your liking and set a very high number in birthrate renderer. Also make sure to adjust the particle parameters of the emiter according to your scene.
    3) Then you can add dynamics in your scene to make it more like. The most appropriate ones I think are the the turbulence, attraction and rotation.
    You will need to fine tune it to match your desired result, by changing the speed or adding also some wind in the scene. Playing then the scene might be hard considering how many particles you have and what kind of computer you have. Keep in minf that there might by plugins that will do this better and easier.
  • Virendra Chandekar
    August 31, 2023 at 9:18 pm
    Thank you very much for the reply. Much appreciated.
