Activity Forums Adobe Premiere Pro Partial audio import failure
  • Partial audio import failure
    Posted by Ethan Mallove on November 6, 2014 at 2:28 am
    I have a video clip which plays fine in VLC and Windows Media Player, but partially loses audio when importing into Adobe Premiere Pro (see below screen capture):
    Notice the “cliff” in the audio track partway through the clip. I’ve tried extracting the audio with Adobe Media Encoder, but the resulting audio still contains a “cliff”. Any pointers are much appreciated!
    -Ethan
    Ethan Mallove replied 11 years, 10 months ago 1 Member · 1 Reply
  • Ethan Mallove
    November 7, 2014 at 3:15 am
    The solution is to clean the Media Cache directory manually. E.g., the below menu item didn’t do the trick:
    Edit -> Preferences -> Media -> Clean
    Instead, I deleted all the files in the Media Cache directory from Windows Explorer:
    C:\Users\\AppData\Roaming\Adobe\Common\Media Cache
    Then, reimporting forced the audio to be “reconformed”, and voila – all my audio waveforms are back!
    Issue resolved.
