Activity › Forums › Adobe After Effects Expressions › parseInt boolean value
  • parseInt boolean value
    Posted by Oscar Nyquist on December 9, 2021 at 1:02 pm
    Hello,
    I’m using a source text property to control a boolean expression (in this case, to set auto leading on a text layer). I know I can just use 0/1 in my source text, but I would like to be able to use true/false instead.
    Here’s what I have:
    aL = thisComp.layer("orderData").text.sourceText.split(",")[3];
    GEN = style.setAutoLeading(aL);
    The string being extracted from the source text is simply the word “true”. However, it still gives me an error, I assume because AE can’t parse the string as a boolean value.
    Is there an easy way to parse the boolean value from the source text property and insert it directly into my setAutoLeading expression? I could of course use an IF statement to get around the issue, but I would like to check first if I’m missing a simpler solution.
    Oscar Nyquist replied 4 years, 9 months ago 3 Members · 4 Replies
  • Andrei Popa
    December 9, 2021 at 1:05 pm
    You could simply check if the word is “true” by changing the second line to
    GEN = style.setAutoLeading(aL == "true");
    If the word is anything else but “true”, auto leading is set to false.
  • Oscar Nyquist
    December 9, 2021 at 1:12 pm
    Thank you for the quick reply!
    That’s a good workaround. Do you have any idea about whether what I asked about initially is simply impossible within the limitations of JS?
    That is, if there’s any way to parse a non-numerical string into a boolean value? Would be good to know for future reference.
  • Dan Ebberts
    December 9, 2021 at 5:21 pm
    I guess you could parse it with eval(), like this:
    aL = eval(thisComp.layer("orderData").text.sourceText.split(",")[3]);
  • Oscar Nyquist
    December 10, 2021 at 3:27 pm
    Cool, thank you very much!
