Activity › Forums › Adobe After Effects › Parenting xy position of object to a null causes it to snap to the location of the null
  • Parenting xy position of object to a null causes it to snap to the location of the null
    Posted by Shaun Rexroat on October 19, 2014 at 2:10 am
    I have a Element 3D object with a xy parameter that I’m trying to parent to my null, but it causes the position to change as soon as I parent it. I only want the position to change when I modify my null’s position.
    Anyone know how to fix this? Thanks!
    Shaun Rexroat replied 11 years, 11 months ago 3 Members · 5 Replies
  • Shaun Rexroat
    October 19, 2014 at 5:54 pm
    I think I meant position expression. I alt+click the stopwatch for the position, and then pickwip my target null.
  • Daniel Waldron
    October 19, 2014 at 9:09 pm
    Pick whip the entire layer, not just the position.
  • Shaun Rexroat
    October 20, 2014 at 3:11 am
    I’m dealing with a layer that has an object within the layer which has its own position, separate from the layer position. When i pickwip the entire layer, moving my null causes the entire layer to move, rather than just the object.
  • Brian Charles
    October 20, 2014 at 4:14 am
    Are you referring to a Group Null generated and linked from within Element or one created from the After Effects Layer >New > Null Object?
  • Shaun Rexroat
    October 20, 2014 at 9:13 am
    I wasn’t, but now I see where I went wrong. I was using the null object created from the After Effects Layer >New > Null Object.
    I feel dumb not thinking of using the group null object. Thanks so much for showing me!
