Activity Forums Adobe After Effects Expressions Parenting to a nested layer that loops!
  • Parenting to a nested layer that loops!
    Posted by Stephen Roberts on July 11, 2014 at 3:50 pm
    Hi Guys!
    Dan Ebberts explained how to parent to a layer within a comp:
    L = comp(“nestedComp”).layer(“layerWithinComp”);
    L.toComp(L.anchorPoint)
    But my problem is that that comp is looping.
    It’s a walk cycle that lasts 1 second. It loops in the main comp. I want to add random blinking eyes that follow it.
    Any thoughts?
    L = comp("nestedComp").layer("layerWithinComp");
    Stephen Roberts replied 12 years, 2 months ago 2 Members · 4 Replies
  • Dan Ebberts
    July 11, 2014 at 4:46 pm
    Are you doing the looping by using a loopOut() expression on a time-remapped nestedComp layer?
    If so, I’d try replacing the loopOut() with a DIY version like this:
    time%key(2).time
    (you make need to adjust this, depending on how you have things set up)
    and then use a similar time calculation to position the other layer in the outer comp:
    t = time%thisComp.layer(“nestedComp”).timeRemap.key(2).time;
    L.toComp([0,0],t)
    Dan
  • Stephen Roberts
    July 11, 2014 at 4:54 pm
    Wow! that works with no adjustments! Thanks much.
    Of course, now I need to pick this apart and figure WHY it worked.
    Thanks again!
    Stephen
  • Dan Ebberts
    July 11, 2014 at 5:06 pm
    I did forget to change one thing back from my test version to match your version:
    L.toComp([0,0],t)
    should have been
    L.toComp(L.anchorPoint,t)
    Dan
  • Stephen Roberts
    July 11, 2014 at 5:08 pm
    thanks again!
