Activity Forums Maxon Cinema 4D Parenting structure of Boole with 3 individual objects?
  • Parenting structure of Boole with 3 individual objects?
    Posted by Joe Rodgers on August 18, 2019 at 2:28 am
    I have a cloud with 3 graph lines that need to appear from the bottom up. I have two of them working but cannot figure out how to add the third one. It would really help if someone could type in an outline of how this would work, I have tried multiple combinations, thanks!!
    Joe Rodgers replied 7 years ago 1 Member · 1 Reply
  • Joe Rodgers
    August 18, 2019 at 2:09 pm
    Okay, for anyone searching same question, I figured it out. As long as the 3 objects are not intersecting each other at any point, you can put all of them in a null as if they were 1 object, underneath the object they are being subtracted from. So, in this case:
    Boole (A subtract B)
    —Cloud(“A” object to be subtracted from)
    ——NULL (“B” objects being subtracted)
    ———Graph line 1(to be subtracted)
    ———Graph line 2 ”
    ———Graph line 3 “
