Activity Forums Adobe After Effects Expressions Parenting Position Retaining Orig Position of Child
  • Parenting Position Retaining Orig Position of Child
    Posted by Drewhalasz on June 8, 2012 at 3:58 pm
    I’ve search for a reference to this specific question for quite a bit of time. I seems rudimentary, but I would love some closure.
    I have to objects on a comp (layer “A” and layer “B”)- I would like to use an expression to parent the position of the one to the other (A as parent, B as child). I’ve been unable to find an expression that does not change the original position of B when entering the expression.
    It either places B directly at the same position as A with this expression
    thisComp.layer(“A”).transform.position
    or displaces B to a different position using this expression
    L = thisComp.layer(“A”);
    fromWorld(L.toWorld(L.thisComp.layer(“A”).position))
    Both of course then allow B to then follow A’s position, but I’m curious if there is a way to have B remain its orig position.
    My work around has been to add +value to the expression and move B back to its orig position.
    Any help would be greatly appreciated.
    Gus Favoreto replied 7 years, 3 months ago 3 Members · 5 Replies
  • Dan Ebberts
    June 8, 2012 at 7:21 pm
    One way to do it is to add layer B’s current position to the amount that Layer A has moved since time zero:
    p = thisComp.layer(“A”).transform.position;
    value + p – p.valueAtTime(0)
    This won’t do anything until you actually animate layer A’s position though.
    Dan
  • Drewhalasz
    June 9, 2012 at 4:06 am
    Thanks Dan! Works Great!
  • Gus Favoreto
    May 21, 2019 at 4:43 pm
    Thank you Dan! I was looking for this answer for years.
    I am trying to add a delay on this expression but is not working. Should I add at the end on valueAtTime(0)?
    Thank you!
    Gus
  • Dan Ebberts
    May 21, 2019 at 5:41 pm
    It would depend on what you’re doing exactly, but this would be my guess:
    delay = .25;
    value + p.valueAtTime(time-delay) – p.valueAtTime(0)
    Dan
  • Gus Favoreto
    May 21, 2019 at 8:51 pm
    YES! Perfect!
    Thank you Dan!
