Activity › Forums › Adobe After Effects › Parenting only one transform value….
  • Parenting only one transform value….
    Posted by Erin Shelby on March 26, 2006 at 3:10 am
    Hi, I want to parent an object to another object (let’s say a “flame” animation layer to a “candle” layer) – but I don’t want the flame to inherit other properties (rotation, scale) from the candle, I only want it to keep it’s distance relative to it’s position. Why I don’t just use an expression on the position of the flame layer (ie: thiscomp.layer(“candle”).transform.position) is because I don’t want it to be exactly on the anchor point of the candle – I want it to be like the parent effect where it stays in relation to the anchor point from when I parent the object. Any clues on a direction I should be going here?
    -grey
    Mike Clasby replied 20 years, 6 months ago 2 Members · 2 Replies
  • Mike Clasby
    March 26, 2006 at 3:38 am
    OK, here’s one way, probably not the cleanest, but it works.
    If you want the “flame” layer to keeps it’s position relative, and that’s all:
    Apply the Effect > Distort > Transform to the flame layer.
    Alt + Click the Position Stopwatch in the Transform Effect to the “candel” layer’s postion. Now with the Anchor Point in the Transform Effect (Flame again) position it relative to the candle.
  • Mike Clasby
    March 26, 2006 at 3:54 am
    I knew there was a better way. Do the expression you mentioned, pickwhipping the flame position to the candle position:
    thisComp.layer(“flame”).position
    then add “+ value”:
    thisComp.layer(“flame”).position + value
    Now adjust the position of the flame to be where you want relative to the candle, you can even change that relative position over time with keyframes.
