Activity › Forums › Maxon Cinema 4D › parenting object to polygons
  • parenting object to polygons
    Posted by Mike Moon on April 5, 2013 at 7:32 pm
    Is there a way to connect an object to a polygon so that if I scale up a cube, and have text resting on top, the text will follow the scale positioning without deforming the text?
    Adam Trachtenberg replied 13 years, 5 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    April 6, 2013 at 4:11 am
    You can do that with a little xpresso. Use the structure manager to determine the index of the polygon you want to stick to and then feed the polygon node into your text’s global position.
    File: 5786_textfollow.c4d.zip
