Activity Forums Adobe After Effects Expressions Parenting nulls to trigonometry-controlled objects
  • Parenting nulls to trigonometry-controlled objects
    Posted by Thomas Hannen on February 8, 2016 at 2:15 pm
    I want to build a digram with arrows between some boxes, where the arrows are connected to the edges of the boxes. So if I move the boxes around, the arrows with change length and angle.
    I’ve read tutorials about how to connect lines to other objects dynamically, using the Beam effect, but I want arrows!
    Using this post – https://forums.creativecow.net/thread/227/6984 I was able to build an arrow that is controlled by two nulls (at the start and end).
    But when I try to parent one of the start or end nulls to another null or object, the parent object doesn’t move the child object.. What am I missing?
    video example here.
    Below are some snippets of my dodgy code:
    arrowlength controlled by
    <code>CellTower = thisComp.layer("startpoint").transform.position;
    Target = thisComp.layer("endpoint").transform.position;
    sizefactor = 100/(effect("ArrowSize")("Slider"));
    BeamLength = (length(CellTower, Target)*sizefactor)-150;
    [BeamLength]
    </code>
    rotation of the arrow controlled by
    <code>CellTower=thisComp.layer("startpoint").transform.position;
    Target=thisComp.layer("endpoint").transform.position;
    // Find the length of side a
    SideA = sub(CellTower, Target)[1];
    // Find the length of side b
    SideB = sub(CellTower, Target)[0];
    //Find the Angle between them
    -1*(270-(radiansToDegrees(Math.atan2(SideA, SideB))+180));</code>
    Kalleheikki Kannisto replied 10 years, 7 months ago 2 Members · 5 Replies
  • Kalleheikki Kannisto
    February 8, 2016 at 5:34 pm
    For your consideration:
    9764_puppetpinarrow.aep.zip
  • Thomas Hannen
    February 8, 2016 at 8:42 pm
    Thanks for the suggestion… I thought about using puppet pins, but I really wanted to keep the geometry of the arrows just right – they seem to look fine though, unless they’re really short.
    Having said that, I still can’t get the two nulls to parent to other objects without everything breaking.
    I really need to be able to dynamically move some boxes attached to the arrows.
    Here are my steps:
    * Load your .aep project
    * Make a shape – a rounded rect box
    * Change it’s anchor point (using, but could just as easily be a manual adjustment)
    * Duplicate the shape
    * Change shape two’s anchor point
    * Reposition the arrow nulls into the right places
    * Parent Null 1 (the base of the arrow) to Shape 1
    See video here:
    https://www.youtube.com/watch?v=bed23MzoUUU
    Immediately the arrow shape jumps off to the side. Why?
    Many thanks again for the suggestion.
  • Thomas Hannen
    February 8, 2016 at 8:46 pm
    I’ve just realised, if I re-write the expression on the puppet pin to point to the shape layer it solves my problem!
    Many thanks-
    I’m still stumped as to why I can’t parent a null to another null successfully though…
  • Thomas Hannen
    February 8, 2016 at 9:19 pm
    Also, by adding a Layer Selector to the expression, I can choose which object the arrow starts and ends from:
    Based on the excellent tutorial by Felt Tips here: https://vimeo.com/104381026
    try {
    L = effect("Arrow Base")("Layer");
    } catch(e) { // catch an error in case layer is set to None. Stops expression crashing
    L = false;
    if(L)
    fromWorld(L.position);
    else value
    February 9, 2016 at 11:54 am
    Parenting messes up the coordinate transformation, and it can get complex. I often end up using “value +” (or a specific value) to change the position. You can get it to work with expressions as well, but I don’t personally find figuring out the right combination of fromComp/toComp/fromWorld/toWorld very easy with a more complex setup, so I just take the easier way.
