Activity Forums Adobe After Effects Expressions Parenting Layer to Null & Adding Expression to Layer
  • Parenting Layer to Null & Adding Expression to Layer
    Posted by Jay Munoz on June 19, 2012 at 7:34 pm
    I’ve been searching online for answer but can’t seem to find what I’m looking for.. maybe someone here can help:
    I have 10 (text) layers tied to one NULL object. I keyframed the Null object to move from point A to point B (top to bottom). I’d like to insert an expression, to all the text layers, which would make them arrive to point B at an offset time. Almost cascade-like. Anyone want to take a stab?
    Thanks, fellas!
    Jay
    Darby Edelen replied 14 years, 3 months ago 4 Members · 4 Replies
  • Wim Bruyninckx
    June 19, 2012 at 8:05 pm
    valueAtTime is something that may be useful for you
    i don’t think it’s necessary to use a parent null layer..
    i would just keyframe the position from one layer from point A to B, and then for each of the other layers: add an expression for the position:
    thisComp.layer(“animated_layer”).transform.position.valueAtTime(time-2);
    where thisComp.layer(“animated_layer”).transform.position is the pick-whipped position value of the keyframed layer
    valueAtTime(time-2) where 2 is the time offset … you can change this value of course…
    hope it helps
    Wim
    thisComp.layer("animated_layer").transform.position.valueAtTime(time-2);
  • Jay Munoz
    June 19, 2012 at 8:22 pm
    Sweet! I’ll try that now.. thanks so much!
    But just to clear it up.. the reason I don’t want to keyframe each layer is because I’m setting it up as a template to use again. I may have to move the position of the text layers here and there for future versions. Any ideas?
  • Dan Fredley
    June 19, 2012 at 8:28 pm
    Unparent the null place it at the top then paste this expression on the position of all layers underneath–must be in order in the timeline since this expression uses the relative (index-1)–in other words it pulls info from layer above). This one only reads the y value if that’s all you want to affect:
    [value[0],thisComp.layer(index-1).transform.position.valueAtTime(time-2)[1]]
    Or if you want to have control over both values:
    [value[0],value[1] + thisComp.layer(index-1).transform.position.valueAtTime(time-2)[1]]
  • Darby Edelen
    June 20, 2012 at 2:31 pm
    Here’s a way to leave the layers parented, just apply this to the position property of the child layers:
    offset = 3;
    p = toWorld(anchorPoint, time - offset);
    parent.fromWorld(p);
    You even maintain the ability to keyframe the position of the child layers independently. The offset value is in seconds. If you want it in frames you could add a framesToTime(); function.
    Darby Edelen
