Activity › Forums › Adobe After Effects Expressions › Parenting FOCUS point to object!
Posted by Editing-jos on February 15, 2006 at 2:18 amI want to parent the distance of the Focus from the camera to a position of an object/null.
This must be done by an expressoin. I’m just such a java noob! Can someone help me write it?
So the expression has to give out a distance between the “CAMERA position vs Object/null”.Regards and thanks.
Oliviano D. replied 13 years, 5 months ago 5 Members · 5 Replies -
Editing-jos
February 15, 2006 at 2:23 amI got this for Motionscript.com. Great site btw.
I think I just have to change some stuff here.
If you can help plz do. 🙂factor = 150;
C = thisComp.layer(“Camera 1”);
L = thisComp.layer(“Light 1″);
d = length(C.position,L.position);
d1 = length(C.position,L.position.valueAtTime(0));
d1/d*factorThis expression calculates the initial distance between the light and the camera (d1), divides that by the current distance between the light and the camera (d) and multiplies that by the maximum value of flare brightness that we want (factor).
So there you have it. A pretty nice effect implemented with very little code.”
Colin Braley
February 15, 2006 at 2:50 amIf all you want is to make the focus distance be equal to the distance between a camera and a null all you need to do is add this expression to focus distance:
nullLayer = thisComp.layer(“Null Object”);
length(this.position, nullLayer.position)adjust the name of the layer “Null Object” and you should be set.
~Colin
Mike Clasby
February 15, 2006 at 2:53 amFor more magic by the same author click on Dan’s head at the top of the page, then scroll down to “Building the World’s Greatest Cameraman”.
Evan Seccombe
August 15, 2006 at 3:29 amhey i have a question along same thing, (and yes, totaly expression/java noob with no idea what im doing) how do i go about llinking a cameras focus distance to an object so that when i move the camera around it, it will stay in focus?
Oliviano D.
April 3, 2013 at 11:56 pmThe distance calculation is good so long the layer is centered and in front of the camera. Otherwise the distance increases and the object becomes out of focus,
For a more advance script check out :https://www.motionscript.com/design-guide/auto-focus.html
target = thisComp.layer("target");
v1 = target.toWorld(target.anchorPoint) - toWorld([0,0,0]);
v2 = toWorldVec([0,0,1]);
dot(v1,v2)
