Activity Forums Adobe After Effects parenting focus distance to null.
  • parenting focus distance to null.
    Posted by Malcolm Desoto on December 7, 2007 at 6:41 pm
    Okay, I’m still a bit inexperienced when it comes to expressions.
    I’m trying to parent a camera’s Focus Distance property to a Null Objects Position property.
    I alt + clicked on the camera’s fd property and linked it to the Null Position Property.
    I thought that would do it.
    Obviously I’m missing something.
    A little help?
    Sam Moulton replied 18 years, 8 months ago 4 Members · 5 Replies
  • Malcolm Desoto
    December 7, 2007 at 6:54 pm
    Okay, the focus distance seems to be parented to the null’s position, but only it’s X space.
    When I move the null side to side, the fd value will change; but not when I move it in Z space, which is what I really need it to respond to.
  • Jason Milligan
    December 7, 2007 at 7:18 pm
    Your expression probably looks something like this:
    thisComp.layer(“Null 1”).transform.position[0]
    Change it to this:
    thisComp.layer(“Null 1”).transform.position[2]
    The reason:
    0=x 1=y 2=z
    Make sure you have your null set as a 3D object
  • Malcolm Desoto
    December 7, 2007 at 7:55 pm
    Ahhhhhhhhh, thanks! Changing the position to “2” makes sense.
  • Darby Edelen
    December 7, 2007 at 9:56 pm
    The other problem you will have is that a layer that is near the edge of the frame will be farther from the camera than a layer that is at the center of the frame, even if they have the same Z position.
    Here’s an expression from Dan Ebberts to correct for this:
    https://www.motionscript.com/design-guide/auto-focus.html
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Sam Moulton
    December 11, 2007 at 5:07 am
    as long as the null is at the same point as the point of interest you can simply use the length arguement:
    length(position, thisComp.layer(“Null 1”).transform.position)
    if the null is not then you need to use a little more complicated expression like the one Master Dan has on his site.
