Activity Forums Adobe After Effects Parenting certain values
  • Parenting certain values
    Posted by Rihards Olmanis on October 27, 2009 at 3:59 pm
    Hi.
    Is it possible (and if it is, then how) to parent only some values (like position, rotation) not whole layer with all its features?
    EXAMPLE: I have shot a video, where 4 persons are stretching a blanket. Each of them is holding their own corner of the blanket. At first they are really close together, after couple of seconds they are approx 2 meters from each other. I tracked all these corners (their hands) and have the Tracker1 in my video with four track points. Went over them – all fine. Now I want to insert a picture as if it was on the blanket. I placed the picture as it should be in the beginning of the video – using Corner Pin tool for it.
    THE QUESTION: Can I parent somehow the x and y of each track point from the video to the x and y of each Corner pin from the picture? Or it is not so simple.
    PS. As you noticed from this post, I am really a beginner in AE, but I have just registered here to solve my problem and I would be glad if someone could help. Thanks!
    Rihards Olmanis replied 16 years, 10 months ago 2 Members · 2 Replies
  • Tony Silva
    October 27, 2009 at 4:33 pm
    there is a corner pin tracking option, so you coulda just used that in the first place. But you can also be able to link the values via an expression.
  • Rihards Olmanis
    October 27, 2009 at 10:53 pm
    I have AE 6.5, so my corner pin dont have tracking options.
    But using expressions the same point has different values (for tracker it is 337,1 , 272,4 , but for corner the same point is 173,0 , 253,0)
    why it is like that? And can I for example type in the expression something like xpos=(allthetrack point 1 data bla bla)-164,1) and ypos=(the same track point2 bla bla) – 19,6)
    would it work (of course If I dont type bla, bla, but all the long text thats in there)?
