Activity Forums Adobe After Effects Expressions Parenting a layer, using ONLY expressions?
  • Parenting a layer, using ONLY expressions?
    Posted by Vince Lund on September 9, 2010 at 10:25 am
    Hi There,
    This is my first post, I hope someone can help me out here.
    I have two layers, currently linked together using the Parent pick-whip. Moving, scaling or rotating the first layer affects the other layer.
    What I want to do is NOT use the parent layer option, and INSTEAD use a set of expressions applied to the Pos, Rot, and Scale properties of the second layer. But I can’t work out what expressions to use, so as to exactly mimic the Parent Layer property.
    The reason for this is that I want to dynamically change the parent of the layer, at certain times – ie, for first few seconds, layer follows Null 01, for next few seconds layer follows Null 02, and so on…
    Any help would be appreciated!
    Vince Lund replied 16 years ago 2 Members · 2 Replies
  • Nick Hill
    September 9, 2010 at 1:19 pm
    You can do something like –
    (layer’s position property)
    L = thisComp.layer(“Null 1”); // rename for your null
    L.transform.position;
    (rotation)
    L.transform.rotation;
    etc.
    But then you’d need to add extra complexity to it to handle the switchover – and if the nulls are in different positions the layer would jump.
    A better solution might be to parent Null 2 to Null 1, and the layer to Null 2. Then just move one null at once.
  • Vince Lund
    September 11, 2010 at 9:31 am
    Thanks, however this would just set my position to the same as the other null’s position… I need it to ‘follow’ from it’s own position, not move directly to a new position.
