Activity › Forums › Adobe After Effects › Parented Layers don’t seem to be moving correctly
  • Parented Layers don’t seem to be moving correctly
    Posted by Dan Hirshon on June 26, 2024 at 5:32 pm
    Hi, I’m working in AE 24.5.0 Build 52 on a macbook pro 2019 (latest software updates).
    I have some markers popping up on the map when I’ve zoomed in on Florida and I parented them to the map there. However, when the map zooms out, the markers seem to stay the same size and position and don’t adjust at all. Am I doing something wrong? I tried changing things so they were parented to a null layer but it didn’t seem to work any better. Thanks in advance for any help!
    https://www.youtube.com/watch?v=7ZZL-zxKxDA
    Dan Ebberts
    replied 2 years, 3 months ago
    2 Members · 3 Replies
  • Dan Ebberts
    June 26, 2024 at 7:09 pm
    It’s hard to tell from what you’ve posted. Is the map zooming happening because you’re scaling the map layer, or is the scaling happening inside a map precomp, or is there a camera move involved? Unless you’re moving or scaling the layer that the markers are parented to, I wouldn’t expect them react.
  • Dan Hirshon
    June 26, 2024 at 8:07 pm
    Hey Dan, thanks for reaching out!
    The map layer (that the markers are parented to) is zooming in because I’m scaling it up. The map is not a pre-comp and no cameras are in the comp either.
  • Dan Ebberts
    June 26, 2024 at 8:31 pm
    Can you post a screenshot of the timeline that includes the scale keyframes for the map layer?
