Activity Forums Adobe After Effects Parented Layer’s Actual Position
  • Parented Layer’s Actual Position
    Posted by Daniel Hashimoto on May 14, 2008 at 8:41 pm
    Hello, if I have a 3D layer that represents, say, a torch. Its anchor point is the handle at the bottom. I then have a null object parented to this layer, aligned with the “lit” end of the torch. Can I pull the actual position values of the null object based on my transformations of the parent layer?
    In other words, I want to attach my particle generator point to the end of the torch, but this is not the anchor point. (keeping in mind it’s in 3d and will need the full 3d location of the parented object. Thank you!
    Shawn Marshall replied 18 years, 4 months ago 2 Members · 1 Reply
  • Shawn Marshall
    May 14, 2008 at 9:15 pm
    Daniel:
    I had a similar question a few years ago. This thread shows an expression that will output the actual 3D position of your parented object. In your case you’ll have to substitute your object for the camera used in the expression Dan provided:
    https://forums.creativecow.net/thread/2/869400#869400
    Hope this helps.
    Shawn Marshall
    Marshall Arts Motion Graphics
