Activity › Forums › Adobe After Effects Expressions › parent/child linking without scale.
Posted by Richie Tovell on December 1, 2009 at 3:09 amI’ve got one layer parented to another but I want the child layer to only accept the position and rotation values of the parent layer not it’s scale, I need the scale values in the child layer to remain at 100,100,100.
Is this easy to do, Anyone?
Regards
Richie
Coda – musical selections; in film, the ending or last section of a film (often wordless).
Joao Monteiro replied 10 years, 10 months ago 3 Members · 5 Replies -
Dan Ebberts
December 1, 2009 at 3:33 amTry this Scale expression for the child:
s = [];
ps = parent.transform.scale.value;
for (i = 0; i < ps.length; i++){ s[i] = value[i]*100/ps[i]; } s Dan -
Richie Tovell
December 1, 2009 at 4:15 amHi Dan, thanks for the help.
No luck this end I’m afraid, the layer still scales smaller and larger, I wonder if it might have something to do with how many children are stacked above it, I don’t know. .
I found an expression of yours for the same thing only excludes rotation, but I couldn’t adapt it to work for scale.
value – parent.transform.rotation
maybe this will offer a clue?
Dan Ebberts
December 1, 2009 at 4:27 am>I wonder if it might have something to do with how many children are stacked above it
Yup – that solution will definitely not work if the parent has a parent. Try this one:
L = thisLayer;
s = transform.scale.value;
while (L.hasParent){
L = L.parent;
for (i = 0; i < s.length; i++) s[i] *= 100/L.transform.scale.value[i] } s Dan -
Richie Tovell
December 1, 2009 at 4:33 pmSuccess!!!
Thank you Dan, I should be able to keep this shot within the comp bounds now whilst it’s deforming, it’s a lot of juggling around with some of the layers being delayed to scale at different times, but I think it’s going to look insane, I also got past my 3D warps problem so in addition to the collapsing of the layers, they can also be warped in to additional 3d shapes, crazy 🙂
Thanks Dan, I envy your talents 😉
Joao Monteiro
November 12, 2015 at 4:24 pmHi Victor,
4 years later in case you still figuring it out.
I believe you were getting that error as you were trying to parent a 3D layer to a 2D layer.
That’s why you were getting the error.Hope it still helps.
Cheers
JoaoMonteiro
