Activity › Forums › DVD Authoring › Parental Lock Programming
Posted by George Harmon on March 17, 2009 at 7:13 pmHi,
I am looking for some examples Parental Lock Out Programming / Scripting. I know it has to do with SPRM13, but how do I list the commands and/or comparisons.
Please help!
George Harmon
george@kfudvd.comGeorge Harmon replied 17 years, 5 months ago 3 Members · 8 Replies -
Eric Pautsch
March 17, 2009 at 9:04 pmLets say you set your players levels are set to PG-13. You could do something like:
GPRM, SPRM 13
Jump Menu x if GPRM < /= 4 Jump Menu y if GPRM > /= 5Menus x can be your main menu which allows access to the disc because your level is PG-13 and below and also assumes you set your player to PG-13 or below
Menu y can say something like “Sorry, this disc cannot be accessed based on current parental settings” because 5 and above is Rated R and up (actually 6 is R rated)
Like all programming, there are a millions ways to do this and this is a simple example. Remember, it depends on the players settings. Also no one sets their parental levels on there players anyway so unless its for personal use – its worthless. I also may be wrong but I dont think this is a required player manufacturing requirement either. In a nutshell – WASTE of time 🙂
George Harmon
March 17, 2009 at 9:12 pmHI Eric,
thanks for the response! However, I do need this programming.
the titles I am authoring are adult and require a parental lock out
by the client. Is there a level higher than 6 (R)?Anything to add?
Best,
George
Eric Pautsch
March 18, 2009 at 1:42 amThere’s an NC-17 setting which puts a value of 7 into SPRM 13. Check in the manual for each setting. It doesn’t matter which GPRM
Also make sure the client knows this is a waste of time unless the parental mode is set correctly on the player….something nobody does. 🙂
George Harmon
April 6, 2009 at 8:30 pmHI Eric,
Thank you again for your help!
Do you have an example of a script to set audio channels / audio set up?
Thanks,’
George
George Harmon
April 7, 2009 at 5:22 pmHi Eric,
I know the Parental setting is useless, by my client wants it. Do you have any Scripting examples that will lead the view to the Player Authorization Code Screen, if the player is set to 6 or lower?
thank you for your help!
George
Michael Sacci
April 7, 2009 at 5:46 pmThe DVD itself can never control the player, bring up its set up screens. All it does is to read the information that it has been set to. You would have to use a menu explaining how to change the settings.
George Harmon
April 14, 2009 at 9:53 pmHI
Can you forward me your direct e-mail address? I would like to ask you a couple of questions, but I can attach anything to the post. I have a script I wrote to set up Parental Lock and Audio Stream. Could you take a look at it and let me know If I am in the right direction?
thanks,
George Harmon
george@kfudvd.com
