Activity Forums Adobe After Effects Expressions Parent Y-scale to a slider
  • Parent Y-scale to a slider
    Posted by S.j. Deluise on March 30, 2011 at 1:25 am
    I’m trying to use this expression to parent only the y-scale of a layer to a slider.
    But I’m getting this:
    “Bad argument: index 1 out of range for stream of dimension 1, Expression disabled.”
    It works fine for x-only when I change it to this:
    [temp[0], value[1]];
    Why?
    temp = thisComp.layer("Null 3").effect("Slider Control")("Slider");
    [value[0], temp[1]];
    People say my motion graphics are moving.
    Dan Ebberts replied 9 years, 6 months ago 3 Members · 9 Replies
  • 9 Replies
  • Dan Ebberts
    March 30, 2011 at 1:36 am
    You’re trying to extract a second dimension from a value that only has one (the slider). Try it this way:
    temp = thisComp.layer(“Null 3”).effect(“Slider Control”)(“Slider”);
    [value[0], temp];
    Dan
  • S.j. Deluise
    March 30, 2011 at 1:39 am
    Yup, that worked.
  • S.j. Deluise
    March 30, 2011 at 1:44 am
    Actually I thought that was the whole issue, but now I’m hitting another snag when I try to use an audio-to-keyframes layer to control the value of Y-scale.
    error: “Expression result must be of dimension 2, not 1”
    a = thisComp.layer("audio").effect("Both Channels")("Slider");
    [value[0], a];
    linear(a, 0, 12, 100, 112);
  • Dan Ebberts
    March 30, 2011 at 2:33 am
    I think this is what you want:
    a = thisComp.layer(“audio”).effect(“Both Channels”)(“Slider”);
    y = linear(a, 0, 12, 100, 112);
    [value[0], y];
    Dan
  • S.j. Deluise
    March 30, 2011 at 3:12 am
    Worked great!
    Thanks again, Dan.
  • Robert Røbke
    March 21, 2017 at 4:00 pm
    Hey Dan,
    what if i want to Parent X-Scale AND Y-Scale to a different Slider? I couldn’t figure it out.
    Would be great to hear from you!
    Thanks in advance,
    Rob
  • Dan Ebberts
    March 21, 2017 at 5:07 pm
    Something like this should work:
    x = thisComp.layer(“Your Layer”).effect(“Slider Control X”)(“Slider”);
    y = thisComp.layer(“Your Layer”).effect(“Slider Control Y”)(“Slider”);
    [x,y]
    Dan
  • Robert Røbke
    March 22, 2017 at 1:48 pm
    Thank you very much!
    One more question – how could i define the anchor point / postion from where it should scale…? ????
  • Dan Ebberts
    March 22, 2017 at 5:40 pm
    You’d need an expression for the Anchor Point (and possibly a compensating Position expression, if you don’t want the layer to move when you change the Anchor Point).
    Dan
