Activity Forums Adobe After Effects Expressions parent with different compositions
  • parent with different compositions
    Posted by Efi Or on March 2, 2010 at 7:08 pm
    good evening guys.
    I want my null’s rotation will be the same as other footage. the problem is…the null in a different composition, so i cant parent.
    I guess that expressions will be the solution.
    could use some help guys.
    I need to parent only the rotation.
    Ben Peterson replied 12 years, 1 month ago 3 Members · 5 Replies
  • Dan Ebberts
    March 2, 2010 at 7:25 pm
    If you just need the null to get its rotation for the other layer, an expression like this should do it:
    comp(“your other comp”).layer(“your other layer”).transform.rotation;
    If you want it to act like it’s parented to a layer in another comp that’s rotating, that’s a different story and you’ll need to provide more info…
    Dan
  • Efi Or
    March 3, 2010 at 5:19 am
    almost there. the expression is ok. no error when using it.
    I just forgot to mention… its Y rotation.
    so .transform.rotation; wont do nothing.
    need it to parent to the Y rotation.
    how can I do it Dan?
  • Dan Ebberts
    March 3, 2010 at 5:29 am
    Like this:
    comp(“your other comp”).layer(“your other layer”).transform.yRotation;
  • Efi Or
    March 3, 2010 at 1:37 pm
    working. thank you.
    is there any site with guides or video guide for expressions?
    will be better if it will be from the easy to the hard..?
  • Ben Peterson
    August 17, 2014 at 10:14 am
    I tried this but for some reason the null rotation cannot be keyframed. It rotates the layer but when I make two keyframes then preview the layer is not rotating.
