Activity Forums Adobe After Effects parent to null but update position date
  • parent to null but update position date
    Posted by Justin Young on February 18, 2012 at 5:54 am
    I have a layer that’s parented to a null. It used to be (or least I think it did) that when you parented a layer to a null and moved the null, the position values of the child changed as well.
    How do I set things so that if I use a beam effect I can make it line up with the position of my child layer and still have my child layer parented to a null that’s moving around everything?
    Roland R. kahlenberg replied 14 years, 7 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    February 18, 2012 at 9:05 am
    You’ll need to look at Expressions, specifically, Layer Transformations. You will require 2 Null Layers, a child layer and a fourth layer to contain the Beam effect.
    Create the parent/child relationship between one of the Nulls (Parent) and the ChildLayer. Then apply Beam to a Solid and set Length to 100%.
    Then apply the following Expressions to the Solid with the Beam effect.
    NOTE: I’ve named the Child Layer as, ChildLayer – make the necessary name change to the script to suit your naming convention.
    Expression for Beam’s Start Point:
    thisComp.layer(“Null 1”).transform.position
    Expression for Beam’s End Point:
    L=thisComp.layer(“ChildLayer”);
    L.toComp(L.anchorPoint)
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
