Activity › Forums › Adobe After Effects Expressions › Parent single path to two other paths and blend between them with slider control
  • Dan Ebberts
    August 8, 2022 at 7:24 pm
    This is pretty limited and not well tested. If the two paths don’t have the same number of points, it doesn’t do anything. It assumes that the slider is on the layer with the expression.
    path1 = thisComp.layer("Shape Layer 1").content("Shape 1").content("Path 1").path;
    path2 = thisComp.layer("Shape Layer 2").content("Shape 1").content("Path 1").path;
    s = effect("Slider Control")("Slider");
    p1 = path1.points();
    p2 = path2.points();
    it1 = path1.inTangents();
    it2 = path2.inTangents();
    ot1 = path1.outTangents();
    ot2 = path2.outTangents();
    if (p1.length == p2.length){
    newP = [];
    newIt = [];
    newOt = [];
    for (i = 0; i < p1.length; i++){
    newP.push(linear(s,0,100,p1[i],p2[i]));
    if (it1.length > 0 && it2.length > 0){
    newIt.push(linear(s,0,100,it1[i],it2[i]));
    }else if (it1.length > 0){
    newIt.push(linear(s,0,100,it1[i],[0,0]));
    }else if (it2.length > 0){
    newIt.push(linear(s,0,100,[0,0],it2[i]));
    if (ot1.length > 0 && ot2.length > 0){
    newOt.push(linear(s,0,100,ot1[i],ot2[i]));
    }else if (ot1.length > 0){
    newOt.push(linear(s,0,100,ot1[i],[0,0]));
    }else if (ot2.length > 0){
    newOt.push(linear(s,0,100,[0,0],ot2[i]));
    createPath(newP,newIt,newOt,path1.isClosed());
    }else
    value;
  • BayarUgrakh Batzorig
    August 8, 2022 at 11:10 pm
    Thank you Dan, this is exactly what I wanted.
