Activity Forums VEGAS Pro parent shadow causes problems
  • parent shadow causes problems
    Posted by Valerie Morrison on June 16, 2009 at 1:42 pm
    I have several “PIP’s” displayed on the screen at one time, each plays a video clip, and they rotate so that each has takes a turn in the front potition. They are all 3d source alpha tracks (for the z-axis rotation).
    I want to add a shadow effect to give more dimension. The only way I’ve found to do this is to use a parent/child relationship, thereby using the parent track 2d shadow. The problem is, this messes up the entire layout. I’m not sure why, and I’m not sure how to fix it. Here are the before and after images to show what I’m getting:
    Any ideas or help much appreciated.
    -Valerie
    John Gordon replied 17 years, 3 months ago 4 Members · 8 Replies
  • 8 Replies
  • Valerie Morrison
    June 16, 2009 at 1:37 pm
    here’s the correct layout (without shadows):
  • John Rofrano
    June 16, 2009 at 4:12 pm
    > They are all 3d source alpha tracks (for the z-axis rotation)… The only way I’ve found to do this is to use a parent/child relationship, thereby using the parent track 2d shadow.
    Your problem is that you have thrown away the 3D information by adding a 2D shadow because you placed the parent track into 2D mode. You can’t do this. Both the Parent Track Motion and the Parent Composite Mode must remain in 3D mode for this to work (which eliminates using a 2D shadow) 🙁
    BTW, Awesome use of 3D Track Motion and reflection. If you didn’t tell people you made this in Vegas, I’d bet that most of them would guess that was done in After Effects. Vegas is a powerful compositing application that not many people take advantage of… Bravo!
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Valerie Morrison
    June 16, 2009 at 5:47 pm
    Thanks John.
    Guess I’ll have to fake it…possibly a solid box with some transparency and have it be a child of the PIP.
    Val
  • John Gordon
    June 17, 2009 at 2:10 pm
    Valerie, I was wondering if you could send me a veg of what you are doing. I’ve been toying with a similar concept but haven’t got it quite right and would like to see how you have set up that project.
    John
  • Valerie Morrison
    June 17, 2009 at 3:12 pm
    No problem John, I was able to get the shadow (faked in photoshop) done perfectly and I’m very pleased with the finished product. I will send you the veg once I get home, but you can watch the video here
    Val
  • Jim Kaye
    June 17, 2009 at 6:32 pm
    Hi Val,
    I, too am really impressed with with what you did. Any chance you can email me a copy of the .veg file as well??
    Thanks much.
    Jim Kaye (jkaye@plasticpack.com)
  • Valerie Morrison
    June 17, 2009 at 7:08 pm
    Hey Jim, I’d be happy to email it.
  • John Gordon
    June 17, 2009 at 7:52 pm
    valerie, here is my email
    John Gordon
    johngordon@cox.net
