Activity Forums Adobe After Effects Parent Position to a Mask Path?
  • Parent Position to a Mask Path?
    Posted by Josh Pigford on March 21, 2012 at 8:44 pm
    I’m trying to have a layer follow a mask path. Right now, to do that, I create the mask, and then copy the mask data to the “Position” property of the layer and that make it appear that the layer is moving along the same path as the mask.
    The problem comes when I need to tweak the original mask.
    Is there a way to parent the Position property to the Mask property of another layer?
    Josh Johnson replied 13 years, 8 months ago 3 Members · 2 Replies
  • Kurt Ingamells
    April 2, 2012 at 10:08 pm
    Here’s how I think you should be able to do it (If you still haven’t)
    Find the layer that you want to parent to the mask and press p to open up the position
    Find the layer with the original mask and press m to open up the mask properties
    Hold alt and click the position stopwatch to bring up some more options
    Click and hold the swirly icon (pick-whip), and drag your cursor over the Mask Path on the other layer and release the mouse button. Hopefully that should parent the two together perfectly 🙂
    Hope that helps
    “Owww even my shadow’s lookin’ good” – The Cat (Red Dwarf)
  • Josh Johnson
    December 10, 2012 at 7:23 pm
    This does not work.
