Activity Forums Adobe Photoshop Parent Child Compositing
  • Parent Child Compositing
    Posted by Joost on April 19, 2005 at 9:35 am
    This may be a silly question for some of you experts, but OK, I will ask it anyway…
    For video editing I work with Sony Vegas, and I love the parent-child compositing technique. I want to do something similar with still images in Photoshop. I see all the possibilities with layers in Photoshop, but I can’t find a way to make a parent-child composite. Can anyone shed some light into my darkness?
    For those who are not familiar with the term: in parent-child compositing two images (A and B) are mixed by way of a third image (C), which is a greyscale image. A white pixel in C means image A is visible, a black pixel in C means image B is visible. A grey pixel in C determines a mix of image A and B. This is in essense what I want with my stills.
    Any help is very welcome. Thanks.
    Joost
    Tim Neighbors replied 11 years, 2 months ago 4 Members · 4 Replies
  • Kim Mackenzie
    April 19, 2005 at 1:42 pm
    This is the only way coming to mind – basically, use a positive of your Layer C as a mask on one layer, and a negative of it as a mask on the other.
  • Filip Vandueren
    April 20, 2005 at 10:30 am
    Hi Kim,
    If both layers were fully opaque to start with, there’s no need to do it for the bottom layer too.
    Because at a input value of 50% grey,
    both layers would be at 50 % opacity, wich does not add up to 100%
    And here’s a faster way;
    • Get the three layers situated in your file
    • make only layer C visible
    • switch to channels and command-click on the RGB-channel -> turns the grayscale equivalent into a selection
    • hide layer C, show layer A & B
    • Select layer B (you should still sea the ‘marchin ants’ of your complex selection.
    • click on the layer-mask icon -> it automatically creates a layer mask that’s equal to the current selection
    If that’s wrong, you should invert the mask.
  • Kim Mackenzie
    April 20, 2005 at 12:27 pm
    Oh duh 🙂 Yer right, of course.
  • Tim Neighbors
    July 9, 2015 at 1:45 am
    I realize this is a very old post, but thought I’d share… select a layer in photoshop and press control+alt+G (on a PC). This will make it a child of the layer below. Make that child layer a multiply layer and put your mask in it with one of the images the parent (directly below), and the other below that. …just another way to accomplish the same thing.
