Activity Forums Apple Motion parameter keyframe bug
  • parameter keyframe bug
    Posted by Jacopo Del morco on December 13, 2010 at 9:16 pm
    I’m trying to modify the oscillation of a shape during time. But i can do it only if the shape is at 00:00:00 . If the shape is in another time postition, the modification of the oscillation is completely desyncronize. If I want to syncronize it i must give the oscillation a start at 00:00:00 until it reach the shape. It’s a desync bug.. Try to make a shape in the middle of the movie and put on it an oscillation; then try to modify the oscillation keyframes during the animation, like speed from 100 to 0. A solution is to create the oscillation at 00:00 and then translate it to the time i want, but it can be done only through Properties windows; if i try to move it trough timeline, it desync !!!
    Jacopo Del morco replied 15 years, 8 months ago 1 Member · 1 Reply
  • Jacopo Del morco
    December 13, 2010 at 10:38 pm
    same problem using ramp to decay speed down… it’s desynched!
