Activity › Forums › Broadcasting › Parallel digital connection issue? Any ideas?
  • Parallel digital connection issue? Any ideas?
    Posted by Michael Klinger on December 21, 2009 at 2:29 am
    We have a few older decks with parallel digital connections. We have a parallel to serial converter, an AJA C10PS unit, which I haven’t yet, gotten to work.
    When powered up and plugged into the parallel out of our d2 decks I get a green lock light on the aja converter, but when I plug either of the serial outs into anything I don’t get a valid signal. Not into a monitor, not into a digibeta deck, not into a scope. I have tried two Parallel source D2 decks with no success and tried all dip switch combinations. The unit we have is supposed to auto-set to either composite/component digital NTSC or PAL.
    Any ideas? Aja unit not functioning properly — or something I am overlooking something?
    Mike Klinger
    Tree Falls Post
    (323) 851-0299
    mike@tfpost.com
    http://www.tfpost.com
    Bob Zelin replied 16 years, 9 months ago 4 Members · 3 Replies
  • Maurice Jansen
    December 21, 2009 at 10:01 am
    hmm
    i’m not sure but i guess the old D2 output’s a 4Fs composite digital signal and not our everyday used component digital signal. i guess everything is actually working but outputting the wrong standard. i guess if you want to use the paralel output you have to use a transcoder (we use the innovision DX210 and DX120 for our VPR3 and panasonic D3).
    or use a highquality composite to digital encoder.
    greet
    Maurice
    People saying they don’t make mistake’s often make nothing at all!
  • Michael Brown
    December 21, 2009 at 7:13 pm
    I believe Maurice is correct that your D2 is giving you a composite signal. I’m not sure you would gain much over just using a composite analog path. FWIW, we have a DVR-20 with the SDI option board, but it’s still just composite.
    Mike Brown
    Video/Film Producer
    American Heart Association
  • Bob Zelin
    December 21, 2009 at 11:41 pm
    the AJA C10PS is still being sold by places like B&H, even though it no longer appears on the AJA website.
    The C10PS is the original AJA product – a parallel to serial SD-SDI converter. If you get a green lock light, it is seeing the D2 VTR. I don’t know why you are getting no output – but I know who would –
    call this # – (530) 271 3190
    Bob Zelin
