Activity Forums Maxon Cinema 4D paper cut animation
  • paper cut animation
    Posted by Cat Pet on March 30, 2013 at 9:09 pm
    Hey there,
    I hope somebody can help me, cause I have no idea how to solve my problem… I have to animate a machine which cuts a paper – the paper goes into the machine and comes out in the cutted form – the cutted paper edges are falling out as waste.
    Anyone has an idea how to achieve this?
    Cat Pet replied 13 years, 5 months ago 3 Members · 5 Replies
  • Brian Jones
    April 1, 2013 at 2:52 am
    cloth or soft dynamics probably, what version of C4D do you have?
  • Rasmus Gerner
    April 2, 2013 at 8:35 am
    Cloth might work best but you can also use an alpha map and inverted version of the same map.
    You could also be using imported vector for your workflow.
    – Rasmus Gerner
  • Cat Pet
    April 2, 2013 at 4:14 pm
    Hey, could you explain what you mean with cloth? I am new to C4D and don’t really understand it.. I already tried using the Thrausi Plugin, which works quite well except that I cannot control the edges where the paper should be cut. So the paper is cut randomly…
  • Rasmus Gerner
    April 3, 2013 at 7:55 am
    If you need to know more about cloth you can always look up a tutorial on the subject.
    If you just want to cut the a simple corner then you could always just use a Boolean.
    Rasmus Gerner
  • Cat Pet
    April 4, 2013 at 1:57 pm
    Okay thank you 🙂 finally i made it with thrausi.
