Activity Forums Maxon Cinema 4D panorama cubic projection
  • panorama cubic projection
    Posted by Petcov Petru on September 17, 2013 at 10:10 am
    does anybody can tell me if it’s possible to create a cubic projection of a panorama,i mean to project the panorama inside the cube.
    in fact what i want is to put some 3d object in the center of that panoramic photo,on the ground and a camera orbiting 360 around that 3d object
    i have a equirectangular panorama and i converted to 6 cubic faces.i tried to put every single of those 6 images to a corresponding cube face
    but edges are very visible,i wonder if it’s possible to get rid of them somehow.i saw it done in after effects in this tutorial https://library.creativecow.net/articles/larsen_carl/cube_world1.php
    but i wanna do it in C4d.
    i tried also project the panorama to a sphere but when i put the 3d object it doesn’t look right because i have no ground i assume
    Petcov Petru replied 12 years, 11 months ago 2 Members · 4 Replies
  • Adam Trachtenberg
    September 17, 2013 at 4:32 pm
    If it’s a standard cross-type projection then you should be able to drop it on the cube in the attached file and be good to go.
    File: 6520_crosstypeprojectioncube.c4d.zip
  • Petcov Petru
    September 17, 2013 at 6:07 pm
    thanks a lot but i’m not sure if you understand me correctly – i want the panorama to be projected on the inside (back) faces of the cube and camera to be also inside the cube and orbit around like you do with standard interactive panorama.
    the edges and corners of the cube it’s still visible
  • Adam Trachtenberg
    September 17, 2013 at 7:10 pm
    Yeah, I think I understand what you’re saying. To make it work you have to put the texture in the luminance channel and turn off specular highlights. Here’s the scene with a texture and animated camera: 6521_cubicenvironment.zip
  • Petcov Petru
    September 17, 2013 at 8:53 pm
    thank you very,very much now i just have to do a little a bit of tweaking for that 3d object to look good when the camera orbits around it
