Activity › Forums › DaVinci Resolve › panny
panny
Posted by Paulson Lang on August 24, 2011 at 2:24 amHi,
Is there a really big difference between consumer and pro plasma monitors? Cause i want to buy for home theater as well as color correction for dcp’s.I am looking in to vt20 series.Am i a bit over ambitious here?
PLJoakim Ziegler replied 15 years, 1 month ago 7 Members · 8 Replies -
Danny Scotting
August 24, 2011 at 4:10 amI have one at home (50″) and one as a client monitor (58″). They are amazing monitors and reasonably priced.
Go for it!!
Danny Scotting – Senior Colourist
Post Op Group Sydneyhttps://postopgroup.com.au/site/?page_id=1052
Jake Blackstone
August 24, 2011 at 5:32 amConsumer monitors can’t do 24P, only 24 psf. Panny wants you to buy the Pro version:-)
Also, you can’t really use Plasma monitor for DCP deliverable grading. -
Paulson Lang
August 24, 2011 at 6:19 amRec 709 is almost close to the p3 colospace for dcp. I would be happy if i achieve rec709 color space in panny vt 20 series model.
pl -
Sascha Haber
August 24, 2011 at 8:26 amAnd what about that weird energy saving mode that dims the screen so drastically its almost impossible to calibrate ?
A slice of color…
DaVinci 8.0.1 OSX 10.7
MacPro 5.1 2×2,4 24GB
RAID0 8TB eSata 6TB
GTX 470 / GT 120
Extreme 3D+ WAVE -
Walter Biscardi
August 24, 2011 at 11:10 amScreen itself is the same for both. It’s the electronics behind it that are a bit different for both. Also the Pro model has a modular input design so you can add / change your inputs as you need. Sometimes the Pro model is cheaper because it does not have a tuner. In fact it used to much cheaper but then the consumer models dropped pretty drastically in price.
Keep in mind the floating white point issue with all plasmas make them a great secondary monitor for the client, but not an absolutely perfect monitor for color grading unless you’re able to calibrate it on pretty much a daily basis. Even then, the white will drift during the day.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media -
Valeriu Campan
August 24, 2011 at 2:02 pmI am considering to use a 42″ gt series panel. I spoke to a calibrator who said that from the current models, only with the x30 series he can access some part of the menu with an access code, and calibrate them close to a reference REC709. I was also told that there is no point doing anything like this unless I run for at least 100 hours, before I book him.
Some reviews here:
https://www.hdtvtest.co.uk/news/panasonic-tx-p42gt30b-p42gt30-201103281070.htm
Joakim Ziegler
August 24, 2011 at 8:42 pmRec.709 is nowhere near the size of the P3 space. Rec.709 is missing something like 40% of the P3 space’s colors, if I remember correctly. There’s a pretty big difference.
Joakim Ziegler – Postproduction Supervisor
