Activity Forums Apple Final Cut Pro Legacy Panning/Zooming with Stills in Final Cut Express
  • Panning/Zooming with Stills in Final Cut Express
    Posted by Cda9er on November 18, 2005 at 4:22 pm
    I am sure that this is a very simple solution, but, it is better for me to just open my mouth and remove all doubt that i really don’t know what is going on.
    I would like to be able to use my images to full effect (they are roughly 3008×2000), and so i would like to be able to pan and zoom with control (directional) on these images. most of them are still. i know that imovie has the ken burns effect, which i was guessing is just a script from FCP that was written as an effect for imovie.
    my problem is that i am seriously struggling to get the basics of putting this kind of effect on my images.
    any help would be appreciated.
    Carol Glover replied 13 years, 6 months ago 5 Members · 4 Replies
  • Enzo Tedeschi
    November 18, 2005 at 9:30 pm
    The most basic way, I guess, would be to animate the stills by keyframing the Motion parameters.
    Cut a clip into your timeline, select it, press enter. This will load it into your viewer. Click the Motion tab. Add a keyframe at the first frame of the clip, and at the last. Do this for the Scale and Center parameters. Now if you park on the second keyframe and change either of those parameters, FCP will animate between them.
    If there’s a more elegant way of doing this in FCP, I’d love to hear from anyone…!
    e.
  • David Battistella
    November 18, 2005 at 10:16 pm
    Just to add to Enzo’s excellent post. You might want to turn the view image and wireframe on in canvas window.
    You park somewhere on the timeline, adjust the image size scale and position in the canvas window.
    Now move down ten seconds and make whatever adjustments you wan to scale, size and position in the canvas and you have created keyframes, if you move back ten seconds and hit play, then you see the changes between the paramters.
    David
  • Todd Gillespie
    November 19, 2005 at 12:08 am
    …now batting third…
    Enzo and David were spot on, but to give you a more contextual feel.
    One of the ways that make the ‘Ken Burns effect’ look so good is the pacing and the flow. Half of that is done with your keyframes, i.e. how fast, how smooth, placement, etc. The other conpontent is the editing/dissolving to the next clip. You’ll probably need to try some different ways before it feels right.
    Also, FCE usually will default to a linear move-constant speed from in to out. BUt sometimes it will look better with an ‘ease in-ease out’ You can right click on the keyframe and choose smooth, sometimes that will make it look even better.
    Good Luck,
    Todd at UCSB
    Television Production
  • Carol Glover
    March 9, 2013 at 3:03 am
    Thanks, but I’m still none the wiser because you don’t explain how to do the keyframes
