Activity Forums VEGAS Pro Panning still image while maintaining ratio
  • Panning still image while maintaining ratio
    Posted by Edwardson Guevarra on February 26, 2011 at 3:00 am
    Bare with me as I am still new to working with Sony Vegas Pro. I am working on a project which has a lot of still images. Everything is set to 1280×720. Originally, I had not set the images’ height and width to 1280×720. I had cropped them and used keyframes to create a panning motion. However, when it rendered out, the video would either show horizontal or vertical bars (letterboxing?). By changing all the images to 1280×720, and then rendering the video once again, the image fills the entire screen.. which is what I wanted.
    The problem is… when I go back to these 1280×720 images, I am unable to use keyframing to create a panning effect. If I were to crop an image just to give me room so I can keyframe, it renders out with the bars either on the sides or top and bottom again. If I don’t crop the image at all and set a keyframe to move to the left, there will be a black bar to the right.
    SO, how do I pan an image while maintaining a 1280×720 ratio?
    Thank you in advance! 🙂
    John Rofrano replied 15 years, 6 months ago 2 Members · 3 Replies
  • John Rofrano
    February 26, 2011 at 4:24 am
    [Edwardson Guevarra] “SO, how do I pan an image while maintaining a 1280×720 ratio?”
    Make sure that your images are larger than 1280×720 because you will need to zoom in a bit to make room to pan. 1.5 – 2x the resolution should be fine. In the Pan/Crop tool, right-click the frame window and select Match Output Aspect. This will give you a cropping rectangle that will match the output aspect of your project. Now you can zoom in a bit and pan around. As long as you keep that rectangle full of the image contents, you shouldn’t see any black bars.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Edwardson Guevarra
    February 28, 2011 at 3:13 am
    Thanks for the info John. Any suggestions for the actual image size?
  • John Rofrano
    February 28, 2011 at 11:58 am
    [Edwardson Guevarra] “Any suggestions for the actual image size?”
    I would make them 2560 x 1440 for a 1280 x 720 project if you plan to zoom in and pan.
    ~jr
