Activity › Forums › Apple Final Cut Pro Legacy › panning and zooming on stills
Posted by Adam Grabel on June 22, 2005 at 7:50 pmI’m a moderate user of Final Cut Pro 4 and need some help with panning and zooming on still images. I know that to do this I need to go into the motion tab in the active canvas, but don’t know how to get the desired effect from there. Can anyone help with a step by step on how this is done?
Thanks in advance.
Kevin Monahan replied 21 years, 2 months ago 5 Members · 5 Replies -
Matthew Brunn
June 22, 2005 at 8:30 pmDo you know how to set a keyframe? If you don’t, you really need to read your manual or go to the help menu. If you do know how to set keyframes, then I’m not sure what you are asking.
Hope this helps-
Matthew
Dual 500 G4
OSX 10.3.5
Ram 1.38
FCP 4.5/AE 6.5/DVDSP3 -
Bill Willins
June 22, 2005 at 8:43 pmdrop photo image on timeline – dbl click to open in Viewer – have scale in motion tab read 120 – park playhead on first frame of clip in timeline -click on motion tab – click on small diamond next to scale ( this adds a keyframe) – now click playhead in timeline to last frame of video clip, then go back one frame (use back space arrow on keyboard) – click to add another keyframe here up in your Motion tab – now change the scale value to 100 – up in motion tab right click on GREEN triangles …select smooth. congrats , you just did a photo zoom in.
you want to import photos at 72 dpi , 900 pixels wide … so you have a little room to work with them. If you start getting pixelation trying applying a small .5 Gaussian Blur from your effects and also use Flicker Filter under Video tab in Effects.
Jeremy Garchow
June 22, 2005 at 9:21 pmIf you are working at dv resolution (and only dv), this program is easy:
https://www.grantedsw.com/still-life/
Otherwise use motion, or preferably after effects for nice moves.
G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
Adam Grabel
June 22, 2005 at 9:42 pmThanks, this is the info I’m looking for. I just needed an idea on how to proceed with the zoom and pan, so that I can play and adjust with it, and get to know the function better.
Kevin Monahan
June 22, 2005 at 10:36 pmclick to add another keyframe here up in your Motion tab – now change the scale value to 100
It is a wasted stroke to add a second keyframe. All you need to do is change the slider or enter a new value and a second keyframe is automatically added for you.
Cheers.
Kevin Monahan
Author – Motion Graphics and Effects in Final Cut Pro
fcpworld.com
