Activity › Forums › AJA Video Systems › Panic!
Panic!
Posted by Bernardo Gortaire on May 27, 2005 at 6:07 amCan I capture analog video with the Kona 2 or it
Chris Tompkins replied 21 years, 3 months ago 2 Members · 3 Replies -
Chris Tompkins
May 27, 2005 at 11:26 amThe Kona 2 has SDI inputs and analog and SDI out
Look @ the Kona LS for analog inputsTry reading up here:
Bernardo Gortaire
May 28, 2005 at 5:42 pmThe reason for the panic is that I’ve already buy 2 Kona 2 cards but I do not have any Digital deck. I bought them because I would like to work with HD in the near future, but I’ll use UVW 1800 Betacam SP decks until the HD is available. If I decide to keep the Kona 2s what can I do to use them with the analog decks? Is it possible to do any arrange with the SDI converters from Aja (Models DC10A and DC10B)? If I get the 2 converters I guess I’ll have to make some arrangement throug a patch bay in order to capture video and audio from the Beta deck and to send it back once edited… Am I right?
Chris Tompkins
May 28, 2005 at 6:47 pmYes, getting the D10A and the D10C converter will solve your problem. These mini-converters will take a component analog signal and convert it to a SDI signal. Also, look at the AJA I/O LA as a converter for all your in and outs.
