Activity Forums DaVinci Resolve Panel Sensitivity Control
  • Panel Sensitivity Control
    Posted by David Koch on July 29, 2011 at 3:05 pm
    Hi together,
    i use DaVinci 8.0 and a WavePanel. It always defaults my “Panel Sensitivity Control” adjustments when i re-open the programm. The manual says there should be a Save-Button but i cannot find anyone.
    Cheers,
    David
    David Koch replied 14 years, 11 months ago 2 Members · 4 Replies
  • Ola Haldor voll
    July 29, 2011 at 3:22 pm
    I would suggest you make your own profile preset. Set up whatever you need for resolution, frame rate, monitoring setup+++ and along with this you can adjust what the trackballs and rings will be like. This is a per preset setup.
    I’ve gone through and made all my presets (R3D2K, 4K, 1080i50, PAL, etc..) have the same settings for the sensitivity.
  • David Koch
    July 29, 2011 at 3:35 pm
    Thanks Ola. Sounds good, i’m gonna do this.
    So i setup everything in the CONFIG window, right? But where can i save these preferences as a individual preset?
  • Ola Haldor voll
    July 29, 2011 at 4:25 pm
    In the middle of the config page you have a set of presets. There you’ll have Save, Load and Save As buttons. These let you easily change between different workflows. Say you’re making a new project using EDL to conform, then you’d want a different set of settings than if you’re conforming using XML. All these settings can be stored in different presets. In these settings, the panel sensitivity is saved too.
  • David Koch
    September 27, 2011 at 2:39 pm
    Got it, thanks a lot!
