Activity Forums VEGAS Pro Pan/crop tool – Render is very flickery on movement.
  • Pan/crop tool – Render is very flickery on movement.
    Posted by Frank Manno on August 10, 2005 at 1:35 am
    I’m using the pan crop tool to rotate a clip and zoom into it a little.
    When I render this out it doesn’t look quite right. Kind of artifacting, or
    strobing, flickering on movement.
    It looks like it’s rendering frames and not fields. I checked the render options
    and it’s definately rendering lower field first (PAL DV).
    SO what could the problem be?
    -Frankie
    Mahesh Upadhyaya replied 21 years, 1 month ago 4 Members · 4 Replies
  • Edward Troxel
    August 10, 2005 at 1:10 pm
    Try rendering at BEST and add Reduce Interlace Flicker.
    Edward Troxel
    JETDV Scripts
  • Frank Manno
    August 10, 2005 at 1:56 pm
    I tried that –
    Also tried rendering in After Effects with the same result. No different…
    Wish I knew what is causing that, I’ve had that problem since day one and never really addressed it. Just accepted it except this time I can’t cause the client is super fussy.
    -Frankie
  • Greg Flowers
    August 10, 2005 at 2:51 pm
    Mabey you could try adding a little motion blur in either application and see if that helps smooth things any.
  • Mahesh Upadhyaya
    August 10, 2005 at 5:34 pm
    I have seen this effect too. If there is some zoom or tilt on the pan/crop, movement gets jaggy. ( we used to call it venetian blind effect in the old analogue days).
    I would welcome a tried-n-tested setting for zooms/tilts in pan & crop which compensates movement.
