Activity Forums VEGAS Pro Pan/Crop repositioning effects
  • Pan/Crop repositioning effects
    Posted by Jacob Hobbs on September 12, 2007 at 8:57 pm
    I have a background image that has dimensions 1260×200. I want to use it as a sort of banner or tv news ticker.
    Currently it is centered across the middle of the screen. I want to reposition it to the bottom of the frame. I can get it repositioned using pan/crop, but the film effect I have applied on top of it, doesn’t stay with it. The film effect gets stretched out across the entire frame. Instead, I want this film effect, to be applied only to the banner/ticker area.
    I tried creating a blank track, adding a blank event and applying the film effect. But I still can’t reposition the effect. It covers the whole frame.
    Edward Troxel replied 18 years, 11 months ago 2 Members · 1 Reply
  • Edward Troxel
    September 13, 2007 at 2:09 am
    That sounds normal. Try this:
    Open the film effects dialog box. To the left of the timeline at the bottom of that dialog is the name of the effect. To the left of that is a small triangle. Click on that triangle. Did that make a difference?
    Otherwise you’ll need to create a mask to get it off the rest of the screen.
    Edward Troxel
    JETDV Scripts
