Activity › Forums › VEGAS Pro › Pan/Crop is not centered
  • Pan/Crop is not centered
    Posted by Fabien Ford on June 26, 2020 at 3:03 pm
    The problem is a little difficult to explain with words, but as you can see in the picture the Pan/Crop is not centered.
    I first thought it was Track Motion being off, but it doesn’t seem to be that.
    This problem occurred suddenly, so I must have pressed something without realising.
    I also don’t get this problem in other Vegas projects.
    Any ideas?
    Francois Pénzes replied 6 years, 3 months ago 2 Members · 1 Reply
  • Francois Pénzes
    June 27, 2020 at 3:23 am
    Hi Fabien
    Let’s try this for starters. If you right click in your preview window, is the ”Scale video to fit…” checked or un-checked ? Does it make a difference in your centering ?
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1 and a bunch of others
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
