Activity Forums VEGAS Pro Pan/Crop
  • Pan/Crop
    Posted by Tyson Onaga on October 30, 2009 at 1:21 am
    I have created a Mask on an image. I would like to have the image move under the Mask. The only way I can achieve this is to make multiple Mask keyframes.
    Is there a way to “slide” a Mask [all points] en masse (L,R,Up,Down)? It looks as if only Mask anchor points can be moved. Thanks.
    Tyson Onaga replied 16 years, 10 months ago 2 Members · 2 Replies
  • Graham Bernard
    October 30, 2009 at 8:49 am
    “Is there a way to “slide” a Mask [all points] en masse (L,R,Up,Down)? It looks as if only Mask anchor points can be moved.” – What is the difference between “Points” and “Anchors” – actually what is a Point?
    Moving on, this is what I do:
    1] The Move Freely Tool is engaged
    2] The Normal Tool engaged
    3] Hold down the ALT key and click on any ONE Anchor. For me, this lites up all the Anchors where I can now “grab” any Anchor and all move all the Anchors “en masse”.
    Grazie
  • Tyson Onaga
    October 30, 2009 at 4:03 pm
    Thanks much!
