Activity › Forums › Panasonic Cameras › Panasonic P2 and Premiere Pro -workflow options
  • Panasonic P2 and Premiere Pro -workflow options
    Posted by Pierreg on April 5, 2006 at 8:39 pm
    My HVX200 is about to arrive, and I am realizing that my Premiere Pro is out of date, my AspectHD doesn’t work with the Panasonic…and the P2 cards hold such limited data. Obviously, I need to do some upgrading and would like to avoid wasting time and money.
    There are lots of suggestions here regarding FCP workflow, is anyone using Premiere Pro who can give me a quick run down of what they have found to be the best most efficient work flow from capture to long term storage. Thanks.
    Steve Freebairn replied 20 years, 5 months ago 3 Members · 4 Replies
  • Noah Kadner
    April 6, 2006 at 12:54 am
    This may be of some help to you as Adobe slowly plays catch up:
    https://www.dvfilm.com/raylight/index.htm
    Noah
  • Pierreg
    April 6, 2006 at 2:08 pm
    That sounds great….is it everything it says it is….do you have experience with this product?
  • Noah Kadner
    April 6, 2006 at 6:24 pm
    I’m an FCP man through and through- but I believe all I’ve heard about this product has been positive so far.
    Noah
  • Steve Freebairn
    April 6, 2006 at 6:38 pm
    Download it and try it out. I’ve quite impressed with how devoted the company is to improving the product. Their last release 1.3 to 1.4 gave 4x the playback quality in a few of the modes. If you read the documentation, it doesn’t transcode your image (except if you are using the lowest setting (red) as an offline solution). The files work just fine in 1.5 and 2.0 and it basically does what FCP does, meaning it makes a wrapper that the NLE works with. Plus for only a few hundred bucks, it is way cheaper than paying for a whole NLE, that has bugs of its own 🙂
