Activity Forums Panasonic Cameras Panasonic NV-GS11
  • Panasonic NV-GS11
    Posted by Sholeh Atashzad on April 24, 2019 at 1:29 pm
    Dear fellow filmmakers,
    I have a Panasonic NV-GS11 camcorder Mini DV. I have tried to connect it to my Mac and Windows to capture the footage I have on the Mini DV tape, but both didn’t work.
    I don’t have a driver disc. I tried to find a driver online but no luck.
    Any suggestions what to do?
    Thank you in advance.
    Roger Poole replied 7 years, 4 months ago 3 Members · 2 Replies
  • George Dean
    April 24, 2019 at 11:38 pm
    Hi Sholeh,
    If I’m not mistaken that camera has S-Video, Composite, and Firewire connection. I would pick up an inexpensive Firewire card and connect using Firewire which should give you the best quality. If the card doesn’t come with software, you may already have software on your computer or download a free app. Ah, that’s for Windows, not sure about the Mac.
    Best Regards……George
  • Roger Poole
    April 29, 2019 at 11:04 pm
    As far as the Mac is concerned and FCP legacy, you need to follow the procedure which is as follows. The Mac can be on, but FCP not running. Connect the camera to the Mac with a firewire cable. Turn on the camera and put it into vtr mode. Launch FCP, then when you go to Log and capture you will see the Camera present. FCP grabs the firewire ports when it launches and wont accept any firewire connections made while it is running. Hope this helps.
