Activity Forums Panasonic Cameras Panasonic HVX Question
  • Panasonic HVX Question
    Posted by Jason Demek on September 18, 2008 at 8:04 pm
    Question here for you all. I’m planning on shooting some footage to telestream to another station. Is there a way to shoot the footage in 16 x 9 then squish the footage into 4 x 3. Then once they telestream the footage can the other station bring the 4 x 3 back to 16 x 9.
    Thanks you all in advance for your input.
    Jason Demek
    Editor/Animator/Director
    WPGH 53: Pittsburgh, PA
    Richard Herd replied 17 years, 11 months ago 2 Members · 1 Reply
  • Richard Herd
    September 18, 2008 at 8:42 pm
    The quick answer is yes. But there’s some details that need clarifying. For example, I use extron scalers Model DVS 304. When you say 4:3 and 16:9, there are a variety of actual frame sizes and cycle rates to choose from depending on the exact specs of each piece of hardware, for example 1024 x 768 @ 60 Hz. The frame size and cycle rate are separate “knobs” you can adjust for both “input” and “output” signals. Moreover, this particular scaler resides on a network via TCP/IP and you can manipulate it remotely.
