Activity › Forums › Panasonic Cameras › Panasonic HPX300 excessive noise and grain.
Posted by Javier Lopez on June 28, 2012 at 4:54 pmHelle gentleman,
I ave an issue with the Panasonic HPX300, I am shooing at -3db gain to minimize excessive noise and grain, I have the same results shooting outdoors under a sunny day or indoors with a light kit, can anyone post any suggestions on the settings please?.
Thanks in advance.
Javier Lopez replied 13 years, 12 months ago 4 Members · 7 Replies -
Steve Eisen
June 29, 2012 at 5:16 amIt’s a known issue. Improvements were made on the HPX-370. You have to play with the settings that appeal to you. Save it to the SD card and your good to go.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group -
Javier Lopez
June 29, 2012 at 3:22 pmGood morning Steve,
Can you please provide any settings suggestion?.
I appreciate your time and response, thanks!.
David Aretsky
July 3, 2012 at 6:32 pmTry This:
Ver 1.00-00
AG-HPX300P
SYSTEM FREQ:59.94Hz
TITLE:DAVE DSCENE NAME :DANGER
00005000: 1 ; VFR : OFF
00005001: 24 ; FRAME RATE: 24 FRAME
00005002: 01AB0708 ; (SYNCHRO SCAN):
00005003: 6 ; DETAIL LEVEL: -2
00005004: 8 ; V DETAIL LEVEL: 0
00005005: 13 ; DETAIL CORING : 5
00005006: 11 ; CHROMA LEVEL: 3
00005007: 8 ; CHROMA PHASE: 0
00005008: 8 ; COLOR TEMP Ach: 0
00005009: 8 ; COLOR TEMP Bch: 0
0000500A: 122 ; MASTER PED: -6
0000500B: 16 ; A.IRIS LEVEL: 0
0000500C: 0 ; DRS EFFECT: 1
0000500D: 4 ; GAMMA : B.PRESS
0000500E: 2 ; KNEE: LOW
0000500F: 0 ; MATRIX: NORM1
00005010: 0 ; SKIN TONE DTL : ON
00005011: 1 ; V DETAIL FREQ : MIDSCENE NAME :FLUO.
00005003: 8 ; DETAIL LEVEL: 0
00005006: 8 ; CHROMA LEVEL: 0
0000500A: 128 ; MASTER PED: 0
0000500C: 2 ; DRS EFFECT: 3
0000500D: 0 ; GAMMA : HD NORM
0000500F: 2 ; MATRIX: FLUO
00005011: 0 ; V DETAIL FREQ : THINSCENE NAME :SPARK
00005003: 12 ; DETAIL LEVEL: 4
0000500D: 2 ; GAMMA : SD NORM
0000500F: 1 ; MATRIX: NORM2
00005011: 0 ; V DETAIL FREQ : THINSCENE NAME :B-STR
00005006: 9 ; CHROMA LEVEL: 1
0000500D: 3 ; GAMMA : HIGH
00005011: 0 ; V DETAIL FREQ : THINSCENE NAME :DAVE V
00005000: 0 ; VFR : ON
00005006: 6 ; CHROMA LEVEL: -2
0000500B: 14 ; A.IRIS LEVEL: -2
0000500D: 6 ; GAMMA : CINELIKE V
0000500E: 0 ; KNEE: HIGH
0000500F: 3 ; MATRIX: CINE-LIKE
00005011: 0 ; V DETAIL FREQ : THINSCENE NAME :DAVE D
00005001: 60 ; FRAME RATE: 60 FRAME
00005006: 10 ; CHROMA LEVEL: 2
0000500B: 13 ; A.IRIS LEVEL: -3
0000500D: 5 ; GAMMA : CINELIKE D
00005011: 0 ; V DETAIL FREQ : THINdangerd
Jan Crittenden livingston
July 31, 2012 at 2:52 pmHi,
Just looked at this list of Scene files and the only issue I have is that the DRS seems to be programmed in to either a 1 or a 3 level. DRS is a feature that when used when needed provides an excellent means of controlling a very wide dynamic range. Used when not needed, will result in noisy pictures. The circuit is always in comparison mode, dividing and conquering over 4028 segments on every frame. If you need it you’ll be happy you have it. If you leave it on for normal shooting beware that you maybe undermining your desired noise floor.
Yes I know it is on a User button to activate, but you need to know how this works and use accordingly.
Best,
Jan
Jan Crittenden Livingston
Product Manager, AVCCAM, AG-3DA1, AG-AF100
Panasonic Broadcast & TV Systems -
Javier Lopez
October 1, 2012 at 10:15 pmHello Jan,
It is just frustrating that I had spent $8000 on this camera to have all these issues, I had purchased the camera in the US and I live in Ecuador now, I will try the settings provided on this forum.
Thanks.
Javier Lopez
October 1, 2012 at 11:52 pmHello David,
I am confused on the settings that does not specify the value (-) or (+), example:
SCENE NAME :DANGER
00005005: 13 ; DETAIL CORING : 5 THIS SHOULD BE (-) OR (+)??.
