Activity Forums Panasonic Cameras Panasonic HMC41 – Frame Rate Issue
  • Panasonic HMC41 – Frame Rate Issue
    Posted by Alan Flint on September 25, 2014 at 6:07 pm
    I hope this query is in the right place, if not, I would be grateful if some kind soul would move it along for me.
    I record church sermons using a Panasonic HMC41 camera, taking a component feed into a Hauppauge HD PVR 1212.
    I have had this set up for about 2 years, and most recordings have been at 1280 x 720, with a frame rate of 50p (Double Pal). The resultant files are quite large, and are subsequently edited (using Sony Vegas Pro), rendered at 640 x 360, and then uploaded to the Internet (not YouTube). In trying to reduce the file size I have changed the setting in the camera to use a frame rate of 25p (normal PAL).
    Looking at the component out setting in the camera, if I have understood it right, it says AUTO.
    The source resolution in the video capture software still says that the resolution received from the camera is at a frame rate of 50p.
    Any ideas why the selected frame rate of 25p is not showing in the video capture software? I really don’t know what to try next, and am really puzzled, so any kind advice would be much appreciated.
    Regards,
    Alan
    Derbyshire, UK
    Alan Flint replied 12 years ago 1 Member · 0 Replies
  • 0 Replies
